CrazyTalk provides the Widget export feature to generate your customized interactive Web Avatar. By using different default Web Avatar projects, you may easily create a web avatar with or without a backboard. The exported Web Avatar can then be embedded into your web page or blog to attract the audience.
In the Project page:
Double click on Web Avatar man or Web Avatar woman to create a web avatar with backboard.
Double click on Web Avatar Lolita to create a web avatar without backboard.
Optionally modify the avatar.
Adjust the talking script of the avatar.
Please note while in the Stage panel:
DO NOT change the names of any talking scripts.
You may adjust the CTS Length and the contents of each talking script except the Look-at one.
The Script_01 talking script is the message that will be played when the audience clicks the Play button included with the web avatar.
When you are prompted to view the result, click Yes if you want to see it in your browser.
Note: |
If you have a Widget Editor installed on your system, you may then use the exported interactive web avatar as a widget in the widget project.
Launch the widget editor and create a new widget project.
Click the Insert Flash (SWF)
button.
Select the SyncVideo.swf file in the same directory where you saved the web avatar.
You may then see the difference between the web avatars with and without backboard when they cover other widget objects.
