CrazyTalk 5 PRO Edition only.
Using the Key Editor, you can also set or modify the Pan/Zoom/Rotation keys for the character.
Select the Pan
in the pane.
If you are using the mouse as your triggering device, please press down and hold the left mouse key inside the facial feature pane.
Move the mouse, the camera will then pan the image along with the movements of the mouse.
Initial View |
Mouse Moves Up |
Mouse Moves Down |
Mouse Moves Left |
Mouse Moves Right |
Click Set Key
button to include the changes into the key.
Select the Zoom
in the pane.
Move the mouse up to zoom in and move the mouse down to zoom out the image.
Initial View |
Mouse Moves Up |
Mouse Moves Down |
Click Set Key
Select the Rotate
in the pane.
Move the mouse left to rotate the camera counter clock wise and move the mouse right to rotate the camera clock wise.
Initial View |
Mouse Moves Left |
Mouse Moves Right |
Click Set Key
Note:
