If you have a script with expressions applied, you can select a partial sequence to create a custom motion clip for further use.
Drag on the Motion Clip track to select a partial sequence.
Right-click on the selected sequence and choose Group from the menu.
You may also click the Group
button.
Before Grouping |
Selection on |
After Grouping |
Click to select a motion clip.
Right-click on it and select Ungroup from the menu. You may also click the
Ungroup
button. The keys
in the motion clip will be dissected.
Note: |
If the property boxes of the motion clip are checked, ungrouping a motion clip will keep the keys in the overlapped area. |
