CrazyTalk also provides shoulder movements to apply shrugging gestures to the CrazyTalk model. These shoulder movements will take effect only when Shoulder Movements under Natural Motion Settings are enabled.
Double-click anywhere on the Shoulders track to apply shoulder movements as follows. You can also select part of the timeline to apply the shoulder movements to that section.
Move the Left Shoulder Strength slider to adjust the intensity of the left shoulder movement.
Move the Right Shoulder Strength slider to adjust the intensity of the right shoulder movement.
Click OK when done.
The shoulder movement is applied to only a small section of the script and indicated on the track by a circle that turns green when selected . Move the circle to other parts of the script as desired or use the editing tools to duplicate the shoulder movements.
