CrazyTalk now lets you apply head rotation and tilting movements to the talking model during playback of the script. These head movements will take effect only when Head Movements under Natural Motion Settings are enabled.
Double-click anywhere on the Head track to apply head movements as follows. You can also select part of the timeline to apply the head movements to that section.
Move the Horizontal Rotation slider to adjust the rotation of the head in the left or right direction.
Move the Vertical Rotation slider to adjust the rotation of the head in the up or down direction.
Move the Head Tilting slider to adjust the tilting of the head in diagonal directions.
Click OK when done.
The head movements are applied to only a small section of the script and indicated on the track by a circle which turns blue when selected. Move the circle to other parts of the script as desired or use the editing tools to duplicate the head movements.
