In CrazyTalk, you may set any project as the default and CrazyTalk will load that project whenever you launch CrazyTalk afterwards.
You need to create and Save a Project first.
Switch to Project page.
Browse the Project Gallery/Custom to display the project saved in step 1.
Right-click on the thumbnail of the project.
Select Set Default Project in the pop-up menu.
Re-launch CrazyTalk and the new default project will be loaded.
Note: |
Every project saved in the Project Gallery can be set as the default project. You may set a project as the default project in which the model or models are with/without script. |
