The Script page is the critical phase in CrazyTalk process of creating a talking message. Here you decide what and how your model talks and specify the expressions, facial movements and special effects that go along with the animated script.
Note: You can download additional text-to-speech voices from Microsoft or browse Reallusion website for more information.
Click the New Script
button to start a
new script
without any keys. The length of the new script is 15 seconds by
default.
To import WAV/MP3 files, click the Import Audio
button to import a speech file in PCM WAV/MP3 format. Specify the name and location of the
WAV/MP3 file using the dialog box and click Open to open the file.
To record sound, click the Record Audio
button.
Click the Record button to start recording. Recording from the specified audio source starts.
To convert text to speech, click the Text-to-Speech
button.
If you have more than one TTS engine installed, you may need to select the engine first.
Type the text in the editor window.
From the Voice Mode drop-down list, select the type of voice to be used by the model for speaking.
Adjust the voice by using the Volume, Pitch, and Speed sliders to achieve the desired effect. Click the Preview button to play back the result. Click the OK button when done.
