CrazyTalk offers you to output Flash , RM, or WMV files for web. Please follow the steps below.
You may output Flash files for the Web:
Select the Flash Files item in the Format drop down list.
Adjust the other output settings.
Click Advanced button
and drag the scroll bar to set the Video and
Audio quality for the Flash file.
Check the boxes accordingly in the HTML section:
Check Produce HTML Page box to create a web page in which the video file embeds.
Check Preview HTML Page box to preview the result after exporting. You must first check the Produce HTML Page to enable this box.
Check Including Standby Motion so the model in your flash animation contains standby motion.
Click Export
Click Web tab to toggle the
output mode.
Select the RM File or WMV File format in the Format drop down list.
Modify the other Output Settings.
Click Export .
