The general output settings for Video, Image, and Web are described in this section.
Check the Export Timeline Clip if you want to export the selected part of the timeline to media format.
Check the Original Resolution option if you want to retain the same resolution as the source file.
Check the Target Resolution option if you want to specify your own target resolution. Select the required resolution from the drop-down box. You can set the resolution for DVD or VCD with PAL/NTSC formats. You may also select the resolution for YouTube to upload the media files to YouTube website.
Check the Crop option if you want to crop model on the sides.
Check the Use Full Image option if you want to display the complete model without any cropping from the sides.
Click the Background Color box to select the background from the color palette.
Specify the dimensions of the output frame by entering the height and width in pixels under Output Size.
Enter the frame rate in frames per second in the Frame Rate box.
