Creating and Adding Motion Clips
Creating Motion Clips
Adding a Motion Clip to the Gallery
  1. Select one desired motion clip in the Motion Clip track.
  2. Click Add button or right click on the selected motion clip and choose Add Clip.
Converting and Adding a Time Sequence into a Motion Clip
  1. Drag on the Motion Clip track to select a partial sequence.
  2. Right click in the selected sequence and choose Add clip in the menu.
  3. The sequence will be converted into a motion clip and add to the gallery.
Note:
  • If you click Add with the Shift key pressed down, CrazyTalk saves the SFX images of each frame in BMP format, which can accelerate the saving speed but increase the size of the motion clip.
