CrazyTalk 5 PRO Edition only.
You can create your own unique puppet profile or modify existing profile from the Edit Property pane.
Click
to deselect all features.
Pick the desired features in the Solo Feature Selection pane.
Click Preview
, press
Space key, and move your triggering device (mouse, by default) to preview the movements of the features selected.
If you are satisfied with the result, click Save Profile
to save
your custom profile.
To custom your own puppet control profile, you may want to adjust the weight for each feature manually.
Click the Edit Property
to expand the weight pane.
Modify the values in the Weight column of the corresponding features to specify the weights of the movements triggered by the device you move.
Click Preview
, press
Do step 3 and 4 repeatedly to obtain the satisfying result.
Click Save Profile
to save
