CrazyTalk 5 PRO Edition only.
The voice for the animated model depends on the audio source for the script. If you create the script by importing a WAV file or by recording using the sound recorder, the model's voice is the voice from the original audio source. If you use the text-to-speech converter to create a script from plain text, you can choose a synthetic voice or the model. However, you can also apply artificial voice effects to the voice for a additional effect.
Note: |
You can download the text-to-speech converter from Microsoft, or browse to Reallusion's website for more information. |
Right click anywhere on the Voice track and select Property in the sub menu. You can also select part of the timeline to apply the voice effect to that section.
Click the Template button to select a voice effect from CrazyTalk's templates.
Select a voice effect such as genie, monster, or robot from the template gallery.
Click the Preview button to play the script and preview the voice effect.
Click OK when done.
The voice effect is applied to the complete speech or voice track.
Right-click anywhere on the Voice track to create custom voice effects as follows. You can also select part of the timeline to apply the voice effect to that section.
Optionally select a voice effect such as genie, monster, or robot from the template gallery.
Click the Modify button to modify the template and create your own.
Check the Pitch Scale box and move the corresponding slider to specify if the voice is high-pitched or low-pitched.
Check the Head Size option and move the corresponding slider to make the voice sound more deep-throated.
Check the Robot option to add a robotic voice effect and move the corresponding slider to specify the intensity.
Check the Echo option to add an echo and move the corresponding slider to specify the intensity of the echo.
Click Reset to clear all settings and restart.
After modifying a template voice effect, you need to add the effect to the custom template. Click Add to add the expression to the custom gallery.
Click Custom to select a custom voice effect.
Select a custom voice effect from the custom gallery. Click Delete if you want to delete any of the custom expressions.
Click OK when done.
