CrazyTalk 5 PRO Edition only.
You can apply comic special effects such as disguising apparel, metaphor effects suitable to the script, or status symbols expressing the nature of the script with CrazyTalk.
Double-click anywhere on the SFX (Special Effects Animation) or SFX-Swap track to apply special effects. You can also select part of the timeline to apply the special effect to that section.
Select a special effect or comic theme from the Choose Theme drop-down box. A set of special effects for each theme is displayed.
Select a special effect from the desired theme to see how it looks on the model.
Click the Preview button to play a small part of the script and preview the special effect.
Click OK when done.
The special effect is applied to only a small section of the script and indicated on the track by a grey box. To apply the effect over a wider range of the script, drag the box to enlarge it. Move it to other parts of the script as desired.
Select a special effect.
Click the Modify tab on the popped Special Effects dialog.
Use the Displacement feature. Click the four arrows to move the special effect. Click the Reset button to clear your displacement settings and start new adjustment.
Move the Speed slider bar to speed up or slow down the special effect.
Move the Size slider bar to enlarge or reduce the size of special effect.
Move the Opacity slider bar to specify the opacity the special effect.
Click the Preview button to see the result.
Press OK to apply the special effect or click Add to add this special effect to your Custom field.
