CrazyTalk now offers the lips setting under advanced facial settings to enable you to make the lip movements as realistic as possible. This setting lets you specify the position of the control points on the lips that are opened first. Click the Lips tab in the Advanced Facial Settings menu to adjust the lips as follows:
Check the Force to Close box to close the lips while talking. This feature is useful when the original image has an open mouth. Make sure that the control points for the open lips are specified correctly while adjusting the wire frame.
To set the position of the lips, click the
arrows to move the lips after selecting the Left
Corner or Right Corner.
Click the Reset button to clear
your settings and start adjusting again.
Click OK when done.
