The 4-point auto fitting for the four basic anchor points allows you to create a CrazyTalk model in a matter of a few clicks of the mouse. This process is entirely automatic and requires no complex frame fitting techniques. Once you create a basic frame to fit the face, you can use the fitting tools to increase the accuracy of the wire frame by adjusting the frame points with more precision.
Click Auto-fit Anchor Points
to fit the wire frame to the face automatically using
the four basic anchor points for the eyes and mouth. The following auto-fitting
dialog box pops up.
CrazyTalk shows its own estimation about the position of the four points defining the eye and mouth position. If you are not satisfied with the position, click and move the blinking indicators numbered 1, 2, 3, and 4 on the image to provide the four points for the fitting process as displayed in the sample image. Click Process when done. Click Reset at any time to cancel your actions and start over.
Note: |
Adjust the four points as close to the correct position as possible to get the best fit for the eyes and mouth features. Do not worry about precise details at this time. Use the wire frame fitting tools for a more accurate wire frame that fits the face closely with the highest degree of precision. Click Close will keep the previous control point. If you just want to change the image instead of creating new, you can skip this process and save time from re-fitting. |
