In the output page, you may export your project for Video, Sequence Images, Web, or Mobile.
Select the desired media type from the four tabs.
Scroll through the Format drop-down box to select the output media format.
Tab |
Available Format |
Video |
Image |
Web |
Mobile |
Note:
In the Output Settings, set the settings for exporting your media files.
Check the Export Timeline Clip if you want to export the selected part of the timeline to media format.
Check the Original Resolution option if you want to retain the same resolution as the source file.
Check the Target Resolution option if you want to specify your own target resolution. Select the required resolution from the drop-down box. You can set the resolution for DVD or VCD with PAL or NTSC formats as well as select various other resolutions for Windows media formats. Select YouTube so you can export media for uploading to YouTube.
Check the Crop option if you want to crop talking image on the sides.
Check the Use Full Image option if you want to display the complete talking image without any cropping from the sides.
Click the Background Color box to select the background from the color palette.
Specify the dimensions of the output frame by entering the height and width in pixels under Output Size.
Enter the frame rate in frames per second in the Frame Rate box.
The HTML options are available if you are in Web mode:
Check the Produce HTML Page to create an HTML page with the media content (Flash, RM and WMV) embedded in the file. The HTML file is saved in the same location as the media file.
Check the Preview HTML Page to preview the HTML page before exporting.
Check the Including Standby Motion so the model possesses standby motion as the media is not played.
If you are in Mobile mode, you may need to specify more settings.
Select the Target from the drop-down box. You can choose a resolution for different brands of mobile phones such as Nokia, Sony, Ericsson, and Sharp.
Specify the dimensions of the output frame using Output Size drop down list.
Move the Video Quality slider to adjust the video quality.
Move the Audio Quality slider to adjust the audio quality.
