Getting Started – Exporting for Web
You can now export your talking image, animation script, as well as the model into HTML format and reuse them in your HTML web pages. CrazyTalk now lets you export the data as well as the HTML code for using the talking message.
To export to web, do the following:
  1. Select a CrazyTalk model and specify its facial features, type of motion, expressions, etc.
  2. Create a CrazyTalk script to specify the animation and speech for the model.
  3. Click the Web tab under Output to start exporting to web or HTML format.
  4. A crop box is displayed on the model. Using the moving tools, move it over the image to decide which portion of the image is exported. Resize the box to specify the output frame size. You can also resize the cropping frame using the next step.
Note: When the crop box is smaller than picture’s actual size, it is red; otherwise, it will be blue.
  1. Specify the dimensions of the talking image by entering the width and height under Image Size.
  2. Check the Playbar option if you want to display a playback control bar in the HTML file.
  3. Check the Frame option if you want to display the playback controls in a frame on top of the talking image.
  4. Check the Menu option if you want to display the playback controls in the right-click context menu.
  5. Select an autoplay option from the Auto Play drop-down box. You can select Auto Play to start playback automatically or Loop to play the message repeatedly. You can also select Auto Play and Loop to enable both options or No to disable both options.
  6. Move the Image Quality slider to adjust the image quality. Alternatively, enter a number in the Image Quality box to specify the video quality.
  7. Move the Sound Quality slider to adjust the audio quality.
  8. Click the Preview button to quickly preview the HTML page before exporting it. The page opens in your default browser and starts playing if you enabled the Auto Play option.
  9. To save or export your model, script, or talking image, do any of the following:
