How can I continue the special effect by
same image but different motion?
Copy a special effect then
paste to another place on the track.
Double click the pasted special
effect and change to another modifiable special effect.
Drag the latter special effect
to come close to previous effect.
How can I break off special effect?
Create a blink special effect
by choose any special effect and making the Opacity value
to zero.
Drag the blink special effect
forward and cover the front, the latter will replace it.
How can I create a model with perfect background
transparent?
A.
You can create CrazyTalk model
by importing the 32 bit bmp image or TGA files. And using
CrazyTalk to changing the background. This will totally
prevent the background moving while character talking.
To remove the background in
your image editor (like Adobe Photoshop) and save as Targa
file. Then Import the .tga file in CrazyTalk model page
will see the result.
B.
Use the 32 bit BMP file.
On the Alpha Channel, to replace the
background with black and replace the front with white.
Then, Import the bmp file on CrazyTalk model page will
see the result.
The procedures to create a
perfect Special Effect with mask are
all the same.
How can I create a sequence special effect
with sequence tga and bmp?
Prepare the sequence images
animation and make sure the image size is same.
Suggest using the external
editor (like Adobe Photoshoo) to edit the mask. Please
reference.
Choose a modifiable Special
Effect and press Modify, then
click Import to import the sequence images.
Select the last image and
continue to press Shift then select the
first image to import can make sure the image order are
same as you prepared.
What is the limitation on creating special
effects?
The maximum images are 36
in numbers. Extra images will be dropped. You can separate
to other special effect. Then using CrazyTalk to merge
it.
The imported image will be
arranged in one image and this image size has 1024x1024
pixel limitation. If the exceeds the maximum size. It
will be stretched.
Maximum number:
6x6 = 36
Maximum size: 1024 *1024 |
How can I create noise signal of TV. ( for
example by using Adobe Photoshop )?
Create a noise image by click
Filter on the menu bar of Photoshop.
Press Noise > Add Noise and then the
noise will be added to the effect.
Change the Hue from Image
> Adjustments > Hue/Saturation. Then save
three images with different Hue value.
Open CrazyTalk and go the
Script page, add a Special Effect.
Select Template>Modifiable and choose
Full Screen , choose A-Full
Press Modify tab and press
Image Import, choose the three image and press Open on
the file dialog. Then click Preview button will see the
result.
How can I create full screen flicker effect
making shock scenario?
Create a Model and copy the
model image and enhance it as a Full Screen Special
Effect.
Original image |
Invert image |
Edit the script by using Surprise
expression.
Then Import the invert image
as a Full Screen Special Effect.
Making this effect flash two
or three times quickly by using empty effect.
Play it you will see the magnified
shock effect.
- How do I use the Emotives
to speed up the script editing process?
After you import a WAV file for
the speech or use the TTS engine to create the speech, you
can choose an Emotive
for the complete message. Double-click an Emotives icon and
it will add complete facial expression morphs based on the
theme of the emotive to your message. Some emotives have comic
effects included with them for additional effect. Switch to
Timeline mode to see
the result of the Emotives. Use the expression strength slider to adjust the intensity of the Emotive.
How can I adding actions and special effects
to animation tracks?
Double-click anywhere on the Face
track or right-click on the Face
track to add facial expressions. Double-click anywhere
on the SFX track or
right-click on the SFX
track add special effects.
How do I use the Undo and Redo functions?
The Undo
and Redo buttons on the right side of the Emotives
and Timeline
tabs as well as on the left of the Model
viewing pane. CrazyTalk 4.0 keeps a history of the last twenty
(20) actions. Use the Undo and Redo options to cancel or redo
your actions and avoid mistakes.
How do I use the Timeline editing tools
to save time?
After you adjust facial expressions,
special effects, or movements of the head, eyes or shoulders,
you can use the Timeline editing tools to repeat the result
anywhere you want in the timeline
To copy an effect, select the
icons for the effect from the timeline and click Copy
or press Ctrl + C.
Then move the cursor to a different location on the timeline
and click Paste or press Ctrl + V to duplicate
the effect .
How do I select an effect or expression
from the timeline and move it to a different location?
Click and drag while holding
down the mouse button to select the effect icons on the
track.
Alternatively, click the start
position and then press the Shift
key and click the end position to select a part of the
timeline.
Drag the selected icons of
the effect to the new position.
How do I create a new custom facial expression?
Using the template facial expressions,
select a facial expression template that is closest to the
template you want to create and then click Modify.
Use the Facial Features and Muscles tabs to adjust the facial
and muscular movements to create a new expression. Press the
Add button to add
the new expression to the custom expression gallery.
How do I achieve perfect lip-synchronization
effects?
While recording sound or importing
a WAV file, make sure that the speech is voice only and
try to reduce the noise as much as possible.
Do not include any background
audio or sound effects; use the background audio feature
for this.
Use the zooming tools to zoom
in on the voice track and then use the Lips
track to select the appropriate visemes or lip sync movements
to achieve perfect results.
How can I improve eye, head, and shoulder
movements?
Only models using the CrazyTalk
virtual eye library will be able to see the animated eyes.
You can add animated eyes to any model, but this may require
that you edit the facial fitting to fine-tune the eye outline.
Use the Eye, Head,
and Shoulders tracks to adjust eye movements for greater effect.
