How do I embed CrazyTalk models and scripts
to MS Office documents or
PowerPoint presentations?
Export the Script and Model data to your hard disk
using the Export Data
button on Web page.
Open MS PowerPoint and click View
> Control Box to open the Control Box.
Click More Controls
and choose CrazyTalk4
Control.
Drag and create an area where you want to insert the
CrazyTalk image.
Right-click the area and select CrazyTalk4
Control Object > Properties to open the property
settings.
Choose the Model
and Script you
exported.
Press OK and
play the slide show to display the CrazyTalk image.
Note:
If you want to use the PowerPoint file on a different computer,
you need to check the Embed
Data to Document option or copy the CTS and CTM files
to the target computer.
How can I reduce the model and script size
when exporting for web?
If you want to reduce the model
size, use the original eyes, background and no teeth when
you edit the model. On the web page, choose a lower quality
setting to reduce the size.
For reducing the size of the script
data, you can choose a lower quality setting and remove some
unneeded special effects from the timeline.
How can I
reduce the exported data size while burning VCDs or DVDs?
For lower data size when exporting
to media, export to RM or WAV with a higher quality setting
or use AVI codecs that are easily available on the Internet.
(e.g. Panasonic
DV Codec) After downloading it, right-click the INF file
to install it.
When you export to AVI, choose the codec you just downloaded
from the Target resolution.
