Home
Products
Purchase
Downloads
Partner
About Us
Download
Buy
Upgrades
Hints & Tips
This hints & tips page has been created by the programmers and artists who developed CrazyTalk. They wanted to make sure you knew many of the tricks they use get the most out of the CrazyTalk product.
1) General Tips
- How can I get the latest version of CrazyTalk and update the new content?
- How can I speed up the editing process?
2) Facial Fitting
- How can I fine-tune the model image for more realistic facial movement?
- How can I make the chin moving more naturally while talking?
- How can I fine-tune the blinking movement for a more realistic effect?
- How can I make the eyes look more real?
- The talking model's eyes always appear to be distorted. How can I remove the distortion?
- How can I improve the mouth movements for a photo with an open mouth?
- How can I avoid background movement without changing the original background?
- How can I change the background of the model?
- How can I quickly adjust the position of the eyes and the teeth using the Advanced Detail Settings?
- How can I used the Close Mouth Points feature to speed up the facial fitting?
- How do I know which control point is the upper or lower control points?
- How can I disable head and shoulder movements?
3) Script Editing
- How can I continue the special effect by same image but different motion?
- How can I create a model with perfect background transparent?
- How can I create a sequence special effect with sequence tga and bmp?
- What is the limitation on creating special effects?
- How can I create noise signal of TV. ( for example by using Adobe Photoshop )?
- How can I create full screen flicker effect making shock scenario?
- How do I use the Emotives to speed up the script editing process?
- How can I adding actions and special effects to animation tracks?
- How do I use the Undo and Redo functions?
- How do I use the Timeline editing tools to save time?
- How do I select an effect or expression from the timeline and move it to a different location?
- How do I create a new custom facial expression?
- How do I achieve perfect lip-synchronization effects?
- How can I improve eye, head, and shoulder movements?
4) Exporting
- How do I embed CrazyTalk models and scripts to MS Office documents or PowerPoint presentations?
- How can I reduce the model and script size when exporting for web?
- How can I reduce the exported data size while burning VCDs or DVDs?
5) Keyboard Shortcuts
