Download
Buy
Upgrades
Multi-character Setup from any Image
  • New! Multi-character setup is easy with the fitting wizard that can identify up to 4 actors in any image. Simply use Select/De-select to add or delete a character.
  • New! 2 major frames for face & full body fitting: Face frame for facial animation; Body frame for full character transformation.
  • The character frame can be in any quadrilateral shape, increase the layout flexibility and make the most of pixel resolution.
Auto Face Fitting Technology
  • The full featured image editor allows you to rotate, crop images, do color correction, and leads you to the face fitting procedure - all in the same environment.
  • CrazyTalk automatically fits the facial wireframe to your image. You can also use 4 simple clicks to identify the corners of the eyes and the mouth. Once finished, you can have the complete control to fine-tune the fitting points.
  • New! Direct image import from your web cam for faster face fitting.
9 Face Profiles for a Variety of Characters
  • Enhanced facial mesh for a wide range of face types to better fit different facial contour, especially for non-human characters.
  • CrazyTalk Face Profile Styles allow you to animate different characters, including human, animal, and cartoon-like faces with realistic performance behavior.
NEW! Face Orientation & Enhanced Hair Mesh
  • Increased facial angle prevents photo distortion during facial rotation.
  • New! Face Orientation function allows you to edit front and side (≦ 45°) images.
  • New! With the advanced hair mesh layer that can handle characters with long hair, horns and ears, you can have accurate and natural animation.
Custom Facial Features
  • Advanced Facial Settings allow you to fine-tune the color, position, scale of the eyes, teeth, mouth and lips.
  • Customize eyes and teeth to perfectly match your character's personality by importing any custom image for the eye and teeth texture.
NEW! VividEye Technology
  • New! 4 layers of eye settings greatly improve the realism of virtual eyes - Eyeballs, Eye Optics, Eyelashes, Eye Shadow.
  • New! Match the right style of the virtual eyes to your character with VividEye templates - Anime, Animal, CG Cartoon, Comic, Human.
  • New! Create intelligent and reflective eyes with EyeOptics feature.
  • New! Use Eye Shadow and Lashes to remove the texture bleeding when the eyes close or blink.
  • New! Facial Cosmetic function adds fashion color and cosmetics to your character.
Masking for Custom Image Background with Realistic 3D Head Movement
  • CrazyTalk's masking tools can instantly remove the original background by using key color picking and tolerance setting. Replace the background with any new color or image.
  • Your virtual host can be transformed from a dull scene to an exciting beach vacation or appear in a sea of flowers.
ModelScriptStageOutput
