Setting the Head Keys
Using the Face Key Editor, you can also set or modify the
rotation/tilt keys of the character head.
Including the Rotation Status into a Key
Select the Head Orientation button in the pane.
If you are using the mouse as your input device, then press and hold the left-mouse button inside
the facial feature pane.
Move the mouse around, and the model will rotate its head to match the mouse movement.
A head key will automatically be set.
Initial View
Mouse Moves Left
Mouse Moves Right
Including the Tilt Status into a Key
Select the Head Tilting button in the pane.
Move the mouse left and right to tilt the model's
head accordingly. A head key will automatically be set.
Initial View
Mouse moves left
Mouse moves right
