Further Body Adjustments
After you create a character with the Actor Creator, then
you may modify specific character segments by adjusting the
elements in each body part. You may add more elements by either applying front or side motion presets.
Transforming the Elements
After the character is created, you may sometimes find weird twists and turns in the body parts.
Select the character and click the Character Composer button to switch to the
Character Composer Mode.
Select one of the body parts that appears twisted.
Click the Sprite Editor button.
Transform the element of the sprite to rectify it.
Repeat the step till all the elements in the sprite are modified.
Click the Back to Stage button and update the character.
