Most of the time, characters in photos smile. However, the mouth shape may not be as natural as you might expect when characters talk in CrazyTalk Animator. This is because the height of the lip corners. You may use the lip settings to lower the lip corners and keep the mouth line as flat as possible.
After you apply a virtual mouth, you may modify the corners of the lips.
Before adjusted |
Lip corners are adjusted |
Check the Force to Close checkbox to close the model's lips. This feature is useful when the original image has an open mouth. Make sure that the control points for the open lips are correctly specified when adjusting the wire frame.
Original Image |
Force to Close: ON |
