Setting Default Project
After creating a project you may have a need to open it repeatedly, especially when sharing with others in a work group. To do this, you may save the project as
a default project and instantly load it each time you launch CrazyTalk Animator.
Switch to Project on the top panel.
Save your current project by clicking the Add button under the Content Manager.
Right click on the newly-added template icon. A menu will pop up.
Select Set Default Project.
Restart CrazyTalk Animator. The new project has now
replaced the initial default project (white background).
Note:
All the settings of the project will become the default project settings as well.
