The settings in this section provide information for your reference during editing or recording. However, this information can not be seen in the output files.
This setting decides the resolution rendered in the working area. If you encounter a blurry result, especially with image-based items, then try to increase the value of this setting to render the working area in higher resolution.
FPS (Frames Per Second) indicates the rendering performance of your system with the current project.
When the World Axis box is on, a coordinate displays in the origin.
The Stage/Composer On-screen Display may show the mode name at the bottom of the working area to indicate if you are in the Stage or Composer mode.
Stage Mode |
Composer Mode |
Activate this box so that each time after you finish with fitting a body, CrazyTalk Animator prompts you a selection if you wish to use the same photo to run the Face Fitting procedure.
Activate this box so that each time you want to save animation to the Motion or Perform custom libraries, CrazyTalk Animator
will prompt you a dialog box to also include the
Layer Keys into the custom template.
An anti-aliased output will produce a smooth image with less jagged edges and pixilated areas. Activate the box to turn the Anti-alias feature on.
Anti-alias Off |
Anti-alias On |
