When you create a back and forth motion path for a character or a prop, you may need it to face the other side at a certain point so that it does not seem to be moving backwards. This is especially useful if you want to make vehicles or strolling pedestrians approach the scene from a distant perspective.
Flip button on the tool bar above the working area. The prop will then be flipped for the rest of the path
unless you flip it again.
