Setting the Default Key
The Default Key helps you retrieve the neutral status of all facial features in a model. You may use it to set neutral keys to all facial features or to retrieve the initial status of them.
Setting Default Key
Each time you want to remove all facial expressions and go back to the neutral expression state, or when you want to remove the transformation keys (rotation, location, scale) and go back to the initial status, then follow the steps below:
  1. Double-click on the desired Face key (in the timeline) to bring up the Face Key Editor panel. Please note that the key already contains offset data.
  2. Select any feature in the Face Key Editor and drag in the interactive area to modify the model's features.
  3. Click the Default Key button and the offset data will be cleared. The model will then turn back to its neutral appearance and the original key will be replaced by a neutral one.
Note:
  • The Default Key feature neutralizes the keys in the Head, Face and Eye tracks inside the current frame.
