Using Special Effects
If you wish to apply special effects to your scene, then you may use the special effects embedded in CrazyTalk Animator.
  1. Prepare a project which you wish to add special effects to.
  2. In Stage Mode, switch to Special FX >> Object.
  3. Apply one of the templates to your project.
  4. Move, scale or rotate the effect to where you need it.
    Note:
    • The special effects provided in the library are all looping animations in .flv format.
    • Object special effects will always appear unless you use the Visible Setting or the Opacity features to set a timing for them to display.
    • Use the Link and Unlink feature to link the special effect to a character's head in order to have the effect follow the character.
