If you wish to combine several static props into one prop, then in stead of switching to the Prop Composer Mode to build a composite prop, you may also utilize the Merge feature in Stage Mode to directly assemble props. After merging props, you may manage them as one single prop with the following benefits:
Note: |
Props with different Z depths |
Characters in-between the merged prop |
