If your DrawPlus work file contains image object. You may often find that the resolution of the object is poor (blurs) when you load the exported SWF into CrazyTalk Animator as a prop, especially when you zoom in the camera to it or enlarge it.
Image object in DrawPlus work file. (Work file dimension: 1024 pix X 768 pix) |
Zoom in the camera in CrazyTalk Animator. |
In order to solve this problem, you may follow the steps below:
