Fixing Breaks
After you export a SWF file from DrawPlus, there are
no certain-rule combinations regarding what can cause the breaks
to happen in CrazyTalk Animator.
The design in DrawPlus.
The result in CrazyTalk Animator.
Fixing Breaks
If the breaks happen in CrazyTalk Animator, then utilize the Ctrl + Q
function to switch to a different status of the loaded SWF to rectify
the appearance. You may need to switch several times to get the correct look.
Note:
The break issue happens when you apply too many skills or effects to the DrawPlus work. It is highly recommended that you
simplify the work as much as possible to reduce the break situations.
If the Ctrl + Q hotkey does not fix the breaks, then you may need to export in alternative methods
before loading the exported files into CrazyTalk Animator:
For single-frame work files in DrawPlus: Export the work file as an image file (BMP - best quality or PNG - with alpha channel).
For animation work files in DrawPlus: Export the work file as AVI video - best quality.
