3D FACE PIPELINE
3D Head Creator. One-click 3D Head Export. Export Talking Scripts.
WORK SEAMLESSLY WITH OTHER 3D TOOLS
(WINDOWS EDITION ONLY)
3D Head Creator Supports both CrazyTalk 8 & iClone 6
With CrazyTalk 8’s shared module design, the new 3D head creator can be launched from either inside CrazyTalk 8, iClone 6 (v6.3 above), or Character Creator (v1.3 above). Also, not only can the 3D Head meshes and textures be exported to iClone, but you can also edit and share the same talking scripts created by CrazyTalk 8.
3D head creation for CrazyTalk 8 and iClone 6
One-Click 3D Head Export
Once your 3D Head editing is complete, use the One-click option and send your 3D head and textures directly to Character Creator and iClone to create complete 3D avatar and full-body animations, or send them to any other 3D tools via 3DXchange Pipeline for a wide range of applications.
View Manual >
Note: Once your Talking Scripts and/or 3D Heads are created, users can then export them to other 3rd party tools via FBX format. For this process you will need CrazyTalk 8 Pipeline, then go to iClone 6 PRO, and finally convert to FBX with 3DXchange Pipeline version. Also, please take note that if you plan to export a copyright character from a content pack, then you will also need the export license for that particular character content pack.
Export Talking Scripts from CrazyTalk 8 to iClone 6
You can edit and share the same talking scripts created by CrazyTalk 8, which have separated actor track editing and Auto Motion effects. This gives iClone 6 users an empowering script editing environment to easily sync talk and head movements, and to help them precisely perform to the tempo of any music.
export talking scripts from CrazyTalk 8 to iClone 6
