Votes
Product:
Character Creator 1
Version:
1.52
Status:
Active
Issue 737
Move, Rotate & Scale not working correctly when Edit Mesh selected
Steps to reproduce:
1. Launch Character Creator 1.52.2204.1
2. Load any character project
3. Select any clothing/skin object
4. In Edit tab select Edit Mesh Mode and then select an area of mesh to edit.
5. Select Move, Rotate or Scale tool to make adjustments to the selected area of mesh.
Actual result:
No Gizmo is visible to complete the desired action.
Expected result:
Gizmo available to complete desired action.
Further testing:
(A). With a mesh area selected and either the Move, Rotate or Scale tool selected click anywhere inside the selected area. The selected tool Gizmo is now visible and active on only the mesh triangle that was selected, however this area can be extended by dragging the mouse over a larger area with the tool still active.
Deselect the mesh area by clicking anywhere outside it.
Select a new mesh area and then select any tool EXCEPT the tool used in step (A) above.
Actual result:
The Gizmo for the last selected tool is active.
Expected result:
The Gizmo for the newly selected tool should be active.
OS: Windows 10
  •  3
  •  2908
Bug
Submitted bywires
COMMENTS (3)
Feedback Tracker Admin
Hi wires,
Thank you for your updates.
Now it can be reproduced in our test environment, we have reported this issue to our Bug Tracking System, please stay tuned for more information.
Reallusion
Dear Reallusion,
As I stated in my message, the problem happens with ANY project - even the default ones.
Here is a link to a video demonstrating the problem:
https://youtu.be/nMjx09HUrmI
Hi wires,
Thank you very much for your feedback.
Regarding your issue, it would be grateful send us your issue project for further checking. May use cloud services such as Dropbox or Google Drive to make the project file available to us.
Your assistance on this will be very much appreciated.
Reallusion
